  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
well ill be drifting in and out of the room got stuff to do on other floors - so if i disappear im not ignoring anyone just working - yuk
oh.. well.. sorrreeeee.. ms double storey house..
lol.. jk
cam, me no likey the idea of truck cores? sounds like somethin a vl turbo owner would do! or sumone who turboes a ford or sumfin lol but i spose ur getting it for free!
anyways back to washing me car
be back later!
adrian:p
Originally posted by Boostzor
Ure taking teh Core off an OKA?? wont that be huge? massive pressure drop?
yea - it is huge (well I haven't seen it yet, but I'm assuming it is) - but will be cutting it down to suit.. as for the pressure drop - I'm not sure.. depends on the construction and what sort of end tanks I get welded to it..
Worst case scenario it's shit and I don't use it.. either way it's costing nada.. :D
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
