  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
well ill be drifting in and out of the room got stuff to do on other floors - so if i disappear im not ignoring anyone just working - yuk
oh.. well.. sorrreeeee.. ms double storey house..
lol.. jk
cam, me no likey the idea of truck cores? sounds like somethin a vl turbo owner would do! or sumone who turboes a ford or sumfin lol but i spose ur getting it for free!
anyways back to washing me car
be back later!
adrian:p
Originally posted by Boostzor
Ure taking teh Core off an OKA?? wont that be huge? massive pressure drop?
yea - it is huge (well I haven't seen it yet, but I'm assuming it is) - but will be cutting it down to suit.. as for the pressure drop - I'm not sure.. depends on the construction and what sort of end tanks I get welded to it..
Worst case scenario it's shit and I don't use it.. either way it's costing nada.. :D
