  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cool.
I waas gonna get my front camber increased to help with the MC day. I think you have said before that 3 degrees would be the max.
What do you advise I get it set to & forgetting tyre wear for the moment would you suggest I leave it set at maximum for my use as it is only a weekend car as you know.
Originally posted by Micko
Cool.
Absolute max and your tyres would last less than 10K before the insides were gone.
Would suggest you try 1.5 deg or so which will give reasonable handling and some tyre life.
Other prob with too much camber is the car wants to duck and weave on all but smooth bitumen.
Cheers
Ken
OK then - it's set to 1 degree or so now so I might leave things as they are.
Regarding the exhaust - can you suggest who I can get to make front pipes that will bolt straight to the turbs (i.e. remove the standard dumps as well) & any idea what I should pay?
You need to make it in sections , ie. the dump including wastegate bleed type pipe ( ala HKS dumps ) and then the front pipes.
Make it as one unit and you will never get them on.
Butler exhaust did a set for S dickson ( grey GTR up your way ) and SWORE he would never do another set.
Jeff Garland at Exhaust Dynamics could be worth a shot but at the end of the day , it is a lot of money for a relative small gain.
Would expect dumps and front pipe will be around $ 1500 for a good stainless setup and you will gain maybe 15KW.
Apexi power fc is about $1700 and have been told is good for 30KW.Also it 5 min job plus tuning
Cheers
Ken
I am still around doing lab write up which is due 2moro :(
cheers
Joe
here is the preview
Abstract:
The isolation and identification of bacteria from a sample of swamp water proceeded over a period of three weeks. The differential and selective methods were used to distinguish colony morphology, samples were observed under a microscope, gram and spore stains. Gram positive organisms and biochemical tests were used to distinguish gram negative organisms. From the biochemical tests, using the API 20E system, it was determined that the organism A (Isolate 1) was Pseudomonas and the organism B (Isolate 2) was Klebsiella. Using some of the characteristics observed of the isolates it was determined that the bacteria in the MSA was Staphylococcus and the bacteria in the NA was Bacillus.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
