paul; u rememeber my exhaust... will it fit?
steve reckons theres big gains to be made especially in spool up so thats good news, guttin the cat apaprently aint too good. i had a look at tit today and i dont think itll work too well. cos id need to get it smooth for the air to pass through
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
heheh I know... I double and triple check on my reports :(
but not here I give no shit ! :) :)
here is more...
Wuchereria bancrofti and Brugia malayi causes lymphatic Filariasis and Elephantiasis, more than a billion people are at risk. These parasites are endemic in at least 80 countries. It is primarily a disease of the poor people because of its frequent prevalence in remote rural areas and disfavored peri-urban and urban areas. The patients are physically incapacitated and cannot work nor live a normal life They suffer from physical, social, psychological and economical disadvantages, physically they are unable to care for self, isolated from the community, family stress and sexual disability. Psychologically they are depressed, hopelessness and fatalism even suicide does occur. Economically it decrease ability to work due to acute inflammatory attacks and treatments are very costly often ineffective. There are health programs to stop the spread of filarial infections by interrupt transmission in all endemic countries, this prevents the suffering and disability of affected individuals. The control is largely depends on the elimination of mosquito breeding sites. There are also drugs available use of diethyl-carbamazine (DEC), Mebendazole and ivermectin. Theses drugs are all effective against the microfilariae, but not as in adults. Individual protection can be increased through the use of insect repellents and bed netting.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
