  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Cam, Any suggestions for a Saturday venue? My cam covers will be back on Friday, and are finding prices on pulleys today:D
See'ya:burnout:
Saturday - well what about a quiet sat arvo beer and chat at the cott hotel or something? or maybe down at the little creatures brewery?
Originally posted by zanda
niz.
Niz, Think had that bug a coupa weeks ago after eating at the rat restaurant with smelly campbell.
I got sick on sunday. reeel sick. no details but it was not nice.
monday about midday I stopped throwing up but had fever through till tuesday. played basketball on wednesday.
rat restaurant? which one was that?
i think my stomcah has been galvanised by lots of cheap pasta meals at the moon.. :D
Originally posted by SHUTO-BOY
mine's been littered by cheap microwave and oven food
yup.. i think that's given me a stronger stomach too! :)
so what do people think of the cott idea for a sat arvo meet re - entry to car show..
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
