hehe - sorry man..
nothin much happenin here - just watchin a bit of tv - more war crap.. the reporting is so biased and half of it is about how they are reporting it??
the chick next door is going nuts - screaming at her boyfriend again.. always entertaining... she's a freak!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Grr to transperth. Bloody unreliable idiots! My buss was 20 min late and he didnt even apoligise. I have had enough of these busses being late. Its becoming a Joke. And i rang up to complain and try to get some awnsers and she was a bitch too!!! Gez its costomer service is all im asking for. I wouldnt be soo pissed off if he said sorry for being late. Do you guys think im asking for to much? because the lady i talked to on the comment line thinks i was. She said he doesnt have to appoligise. Well they are running a service. If they cant provide the service proply then they should be appoligizing!
