  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehehe - sorry.. zorst is cat back.. dump and front pipe to go on in the next few weeks.. came with the car.. i think it's 3" with 5" tip? typical jap style stainless muffler... don't have any info on it tho...
