  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Jeezus you guys can whore!!!
I go do some work for a bit and BAM!! 5 pages!!! :D
Me looking to move either to Northbridge, West Perth, Subi or East Perth in about a month. Sick of the place I'm in.
Have found a place in nthbridge - bit pricey tho at $250. May have Zanda moving in, may go it alone, may get someone in.. so if anyone's looking and they aren't a dick then PM me..
Hey Niz are u and Vspec joined a the hip or what? right after he posts.... BAM :D hehe
On a more serious note: So its another stroke? as longas they catch em quick they are getting good a treating that kind of stuff. my grandma had one a while back and she almost fuly recovered
