yeah i dont know why i just used to freeze up around guys i liked. Must of just been an immature thing still prefer guys to make the first move but least i dont freeze these days.
Kyles my mums weird - doesnt really care who i sleep with as lnog as its done discreetly and im no riding everybody in the neighbour hood but she cares more about what i wear - if i go out clubbing she's often - u cant go out in that u look like a **** - she's scared someone going to rape me cos im showing a bit of flesh.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahahaha i see the topic is sex again!
hahaha my parents know im a **** its a bit obvious wen u hav a different girl coming round each week! oh well they dont care mum just always tells me these stories of how her friends son made a girl pregnant and stuff like that 2 make me feel guilty
oh i used to get lectures specially when your 16 and your boyfriend 22 and my grandma got preggers at 16 by her 22 year old boyfriend - she saw history repeating itself so she always used to give me the big long in depth story on dads birth - yuk!
kyles the way some mothers speak to their daughters is so unjust! My mum has said some pretty mean thins to me too but im someone that will bite back and we'll fight it out and get it out of our system.
If she wanted me to stay innocent she should of kept her damn employees away from me - one of thems brother was boarding with us so he stayed over one night and made a grab for me in the middle of the night friggin scary thing when your 14.
yeah my friends got a mother that basically disowns her - has kicked her out on the streets many a time - and my friends a good person - far better to her folks than i have ever been to mine - she just cant understand it....... look at it this way - you'll become a better parent yourself cos your aware of it and how it made u feel ;)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
