  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
ive been caught out *blushes*
Im the other side of the suburb from Ray - probably could give u the directions himself - my dad is mates with his brother.
I think after what Frank did to Rays car , I don't think there mates atm though:D
Cheers
Ken
yeah i spend too much of my time daydreaming Joe - when i used to catch the bus too and from work *shudder* I quite often miss my stop cos i was too busy off in my own world - i find it pretty hard to concentrate on anything is my problem
hahah true... you do day dream too much...
just tune out the reality, it can be bad especially when you are driving hahahahah :P hey but then again Issac newton spend his childhood day dreaming :)
haha yeah its been long time since ive been to Ray's house - when the injectors were playing up in the ZX - wish i had the many imports just lying around in my backyard ...... guess ive got two - its a start :P
I dont do it often when im driving Joe - mainly when im sick or tired. You caught me on a bad day i think.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
