Originally posted by GTS-t VSPEC
Why are you guys timing this? Surely it the content that is important, not the speed:p
See'ya:burnout:
wtf ??
Since when has the content EVER been important in whoretown.
In fact when has any sense ever been important .
I should know , I've read your posts.:P
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Shan,
1) SO she's seen the pics of me and you?
2) Troy, I can't wait to see these plates, nerd:p
3) Ken, Wondered why you had a trench coat in the GTR:p
See'ya:burnout:
1 so that what the avatar is really
2 u'll laugh then u'll cry, then'll u'll call me names
3 thought u knew that
Ken,
She thought you were flashing her a wrinkle:p
See'ya:burnout:
Hmm , prolly better than your winkie tho:D
*I will see your winkie and raise you a wrinklie.*
* WHAAAT , is that all you got . Bwahahaha*
Cheers
Ken
Shan,
Got to love that, so you keep your private homo stuff seperate?
See'ya:burnout:
I've just worked out why you live alone.:P
No lock on the puter hey?
Cheers
Ken
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
