  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by predator666
Yeah, are regulars have gone farkcoffee and our post-bot "Dark" is in for repairs.. aggg! WE WILL COME BACK!!! I SWEARS !! :bahaha:
dark a post bot bwahaha he cant hack
he comes here to chat up the chicks and can't keep up then hehe
Nope Adrian is gone, he was going 100 times before he actually went though. Thanks Paul, about time. What did my Dad say about what? Oh, yeah, he said I have to watch you, bit like what the other guys said ya know, chattin up all the girls!
Hey i did say hello n welcome to SAU :)
people usually ignore me but cmon.....
Paul
Dammit
I just arranged to go shopping
so whats it gonna be?
Beer or not to beer?
We could just leave it tonight..
Niz
Joes gettin meat for all of us ok :P
Can anyone get bread rolls and salad or is that my job?
Ive got a bit of cleaning bbq area to do :D
Niz,
CAn you get some meat for me, no salad, I won't have much time with all the places I got to visit:D
Bayley, There are plenty of weirdo's hang around with your dad, but I'm quite safe, really:D You going to Waneroo on Sunday?
See'ya:burnout:
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
