  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
haha.. and some ppl say i bullshit..
even if he did have it.. would he be able to drive it?
for a first car..
i wanna get a mitsu galant vr4 [the old shape one]
coz its an evo underneath.. in a family car guise..
and then get a r34 gtt.. :D
my first was a 2.6l 4cyl TR magna exec. I gave that car some shit :(
Psiker
yeah troy i am what about u? i should be anyways depends if i get my car back in time from the tyre shop!
adrian :D
ken, boosted_rb26 is suppose to be getting his license this coming friday 11th and guess what lol his car is a r32 gtr!
adrian :(
Originally posted by Psiker
hrmm. ok i might be wrong. i heard his parents bought it for him. prolly was lying though. it was a fair while back when i didnt post much
Psiker
"neo gt-25" or something like that has an r34 gtt... his parents bought it for him
its NA tho..
my first was a 2.6l 4cyl TR magna exec. I gave that car some shit :D
Psiker
u drove a magna like its not to be driven EVER..??? lol
its NA tho..
i drive my excel like its not to ever be driven. thats why i need a turbo. im too hard on my cars. and they hate me for it
Psiker
Originally posted by skyzerr33
oh dark
kyles says ur a cheaky little bugger and laughed her head off
then said my gawd hes only my sisters age
hehe
shes kewl
haha.. thats cool
as long as she's not pissed off at me.. and is neve gonna talk to me again??
hahhahah troy. it was funny when he was trying to pick niz up :(
even if he was joking
Psiker
(yes i do read everything)
i'm trying to pick up this chick at school..
well.. actually 3.. lol
if i fail with 1.. i have 2 more.. if i fail with 2.. i have to put all my efforts into the last one.. :D
in ur excel.. have u ever like blown the engine or something? from driving it too hard?
surprisingly no........ it doesnt like the rev limiter though. and i have figured out how to get some wheelspin changing into second :( i should be ashamed :D surprisingly also my clutch is still in good shape
Psiker
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
