  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
camin hes worried hell upset lauren bcause the truth of who he is has now come out. and it wasnt very nice how it did
Psiker
if munkey didnt start the thread.. then i'd still be living a lie :D
darK - yes she is, not sure on the date yet b4 we get maried. life is easier like this atm. specially since she has just started her first ever job
Psiker
congrats on getting engaged.. :D
how long ago was it?
