  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
joe u say magna one more time and i will slap u from here to iraq my boy!
Got it off a friend Dark :D Its a blue R34 GTR - sweet poster should really get it lamenated before i ruin it! Trouble with car pics in your room - it distracts guys attention haha
isnt it kinda awkard to have guys in ur room when ur family is at home..
thats how i feel.. if i ahve a girl over at my house..
its really awkard.. so after the first time.. never again.. only to movies, city.. etc
Originally posted by Pva_Glue
"it distract guys attention" - hahhahaha lol what kinda  guy wont be attracted by the car posters :D
a gay one then again u would be surprised the number of guys that have no clue about cars out there - had to explain what a blow off valve was to about 5 different guys in QLD.
Originally posted by tenzero
Not bad thanks Joe.
Glad to see you pulled up so well.  Macka has a champion photo of you balancing on his brick wall with lightning in the background.
hahah that was 3am in da morning! :D;)
where is it? I want him to upload them!
are u at mack's?
I went over Macks earlier this arvo to help with the mess and get him to come look at an R33 GTS-T with me. I'm not nearly as clued up on these things as Shan and Mack. But the place that has the car wasn't open so we got another half carton and had a few more beers.
So I have to go look at me potential new baby on Monday.
soooo - hmmm i think this is the first saturday night in a long time that ive been online sober haha
i havent been drunk in a while now..
about 4 months..
i saw a guy drinking bourbon on tv.. and i wanted some ...
my mouth watered.. but.. no alcamahol for me :D
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
