Originally posted by Nizmo
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Wheel Balance or your nuts are loose.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as in steering wheel loose? how do i tighten it - cos i wouldnt be surprised if that is the case :D
wheel.. as in allow wheels..
not ur steering wheel..
watch out..
coz it could fall off.. and do a lot of damage
Originally posted by tenzero
Thanks Ken will do. I prolly would have used the RAC if you hadn't said that...so good timing.
Cheers.
D.
The RAC will spend more time doing the
* rip in seat , mark on rear squab , dirty hoodlining type report which any schmuck can see by using there eyes.
The important , check front end play , compression or leakage test, check syncros and oil cond test are bypassed cos they are baffled by the lack of V and too many camshafts.
Cheers
Ken
Cheers
Ken
Nice, will keep all that in mind when I need to get one checked out.
Cheers.
D.
Wheel balance done last week - alignment done this week and the guys that do it are pretty good at what they do - so i ruled that out!
Well then they must have got it wrong then.
Have you hit any kerbs or suddenly heard a loud bang not long after the wheels were balanced ?
cheers
ken
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
