  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey i havent hit any curbs since the ZX - ive been a very good girl- the rear was quite out of alignment tho apparently.
Nah im pretty sure they did it properly - im good friends with these guys i'll beat them up if they didnt but they are really fussy so i dont think its alignment/balance related!
Originally posted by Nizmo
haha :uh-huh:
Forgot to add
* hanging around any SAU guys under 40 *
your chances are increased with me cos I can just say to them it's ok , she's my daughter , go for it . Hehehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
I just read that your having a spa after washing your car, I could blow off the racing and come help:D I'll fix your wheels:D
See'ya:burnout:
Blowoff , ahhh pwpt60secf has returned.
Whats she gonna do for the rest of the arvo.
Cheers
Ken
Niz,
See'ya:burnout:
Are u feeling ok paul? no really? i think there mustve been a typo - i thought u said blow off racing - doesnt sound like you at all haha :)
Niz , it can ONLY be alignment , balance related.
Did they check the top arm bushes , make sure the wheel nuts were tight after they balanced the wheels , made sure they cleaned the mags before putting the wheel weights on .... ?
Cheers
Ken
Dark, If you nice to me for the rest of the week then I'll send you the CD:D
paul.. i've been nice to you since ever..
next week.. :) school holidays start soon :D
finally.. the crappy laptop comes in handy :D
Niz,
It definately sounds like alignment, nothing against your friends but you might want it checked.
See'ya:burnout:
Paul , unless the alignment is so far out it's visual theres a problem , then it is balance ie. Rotation of the wheel , not direction of the wheel.
Cheers
Ken
Niz,
I'll make an exception:D
Ken, If she was your daughter then I would be grossed out, knowing that you had sex:bahaha:
See'ya:burnout:
Face it paul , your parents had sex too.
Though I'm not sure if you know who they BOTH are...:)
Cheers
Ken
ive got a sheet with a whole lot of figures of what they checked how much each thing was adjusted by etc etc - but its in my glove box. honestly to look at the wheel all i would be seeing is a mag and a tyre - i couldnt tell all those things. I know everyone stuffs up sometimes - but these guys are really fussy - hehe even if it is another one of those places i get hottie discount at :)
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
