  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Niz,
There isn't much hope, they own commodores and flying ducks. your doomed:p
See'ya:burnout:
Can just see it in 20years.
Chenille curtains , lino in the kitchen , big hairdo and picks of Peter brock on the fridge, 5 snot nosed kids and one in the oven with the hubby driving the fool sic ute mate.
hehehehe
Kill yourself Niz
Kill yourself NOW:D
Cheers
Ken
like one of those duck mating call whistles they sell at the markets ken.
Paul yes they are sad - but since i look nothing like my dad theres a good chance im adopted *pls god make it so* haha
yea , you wouldn't look as attractive with a 5 o'clock shadow
Cheers
Ken
The sad thing about that Ken is - my mum actually tries to chat guys up in holden utes for me. The odd occasions she's in the car she goes " quick catch up to that ute" im like why? "cos mostly guys drive utes and he might be single" hmmm yes what always wanted a BnS king.
Niz,
Adoption has always appealed to me:D
Ken, I hope you carry tissues for when you dog :spew:
See'ya:burnout:
Paul there are only 2 types of men in this world
Wankers and liars
Cheers
Ken:D
What , she thinks your that unattractive you can't pickup guys by yourself.
Change that
Kill your mother
Kill your Mother NOW
Cheers
Ken
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
