  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i think we got some stuff sorted.. i know i have to go and work out what i need to do to finish the car... :)
me way tired and too pissed for this.. am going to go crash...
mite ring tomorrow about the masters paul if i get zanda's car back together in time...
nite guys...
