  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey Dark :(
haha micko i thought exactly the same thing!
U got the Sunday Time TV guide - marlows are advertising his wing for the low low price of $189 haha now he's going t have all these little trevvies looking like him haha
