  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Niz,
Only if your getting your bikini line waxed:p
Ken, That's cruel, my head is my best feature:p
See'ya:burnout:
Yep , thats what makes it so sad that you think you have a chance with women.Hehehehe
Cheers
Ken
Russ, thanks for the offer, but the blades may break on all the hair:p
Ken, Might take me hours to do it properly:D
See'ya:burnout:
Hours , I was thinking about selling tickets.
Roll up , roll up , see pwptf actually doing work ably assisted by his bikini clad sidekick.
Cheers
Ken
there u go i get the bikini wax done put on the bikini and get my car washed hehe and knowing my luck it'll rain and be teh coldest day on record :P things i do to get out of washing my own car haha
Niz,
Fun? I don't think it would be classed as fun:p
See'ya:burnout:
Roll up roll up
Watch pwptf writhe in pain as we apply hot wax and pull his hair one by one.
Cheers
Ken
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
