  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
speaking of rice i picked up a missile switch so you hav 2 show me where 2 put it paul!:P
Missile switch ???
You been called up to help the air force in Iraq ??
Cheers
Ken
Originally posted by GTS-t VSPEC
Russ,
I'll tell you where to stick it:p Tell me when your free and I'll come over and show you:D
Aidwin, You do and you die:p Do you like older men like Ken?
See'ya:burnout:
Err , I think he likes my cars, pwpt60secf.
At least I pray thats who the kisses were for.
ewwww!!
Cheers
Ken
Aidwin, Nothing wrong with dreaming about GTR's, but your dream includes Ken naked in the GTR:p
See'ya:burnout:
Youn REALLY are a sad man.
Maybe you had better not chaperone Niz , she might not get here intact.
Cheers
Ken:D
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
