  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alright im losing it.
I send this app form to Client in albany and he sends it back AFTER 3 MONTHS!!!! the insurers are getting pissed and say "where is it".
Im thinkin "thank god, finally"
I open the form and he only filled out 1 of 20 pages!!!?!?!??!?! wtf???? i dont get it i gave him step by step instructions, what more can i do.
What agreat way to start the week no wi have to suck the insurers ass to get them to extent the already extended deadline.
*sigh* "this job would be great if it werent for the people"- Shaun C (customer service)
It is acceptable to sit cross-legged on cushions or sofas in people's homes but it is still insulting to display the soles of the feet or shoes or to accept food or anything else with the left hand. It is polite to drink two small cups of coffee or tea when offered. Guests will generally be expected to share a bedroom since guest bedrooms and privacy are almost unknown. Sports clothes may be worn in the street and short dresses are acceptable. Smoking is very common. Revealing clothing should be avoided.
Will stay away from bahrain too there goes half my wardrobe :D
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
