joe if im not mistaken theres a lot of chinese in that last post - i learnt japanese my dear and i said my japrish aint great. Its ok Joe it will be swift and brutal not long and drawn out - u shoould find osme comfort in that thought at least haha *jk*
Niz laughs at Pauls suspension testing kit :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Ken - it is the pre-mixed stuff. Good for 4 years or 20,000kms. Meets many perormance requirements (as per sticker on box) & didn't seem to be any different to the other stuff.
I drained it by pulling off the bottom hose - then I realised that the radiator has a drain****...doh!
If you pulled off the hose then you got about 95% of the old stuff out so it shouldn't be a problem. I would have used the genuine Nissan stuff but I think it is all pretty much the same.
For psikers benefit , if it had been glycol based then they wont mix properly with water based ones and form an oily scum.
Cheers
Ken
hehehe , it bleeped your c o c k too !
Originally posted by 33Spec2
hahaha if it works like that id be grabbing every second girl i saw!:D
Russell - it doesnt work! as i said to joe its lucky he got me who laughed it off and not someone else cos he would have a mighty big bruise on his face by now - i may look weak but i can throw a mean punch :D
Cheers
Ken
i know this. :D was aa bad atempt at a joke :D
Psiker
Cheers
Ken
Thanks Ken - reason for the effort was that I was checking out the radiator cap yesterday & noticed that the overflow tank was empty & the radiator level was down to the core. Seems the bubbling you commented on was in fact due to a dodgy cap.
BTW - interesting that if you make your **** bigger, i.e. c o c k it doesn't bleep it out - there's gotta be a lesson in that somewhere!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
