  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Russell - it doesnt work! as i said to joe its lucky he got me who laughed it off and not someone else cos he would have a mighty big bruise on his face by now - i may look weak but i can throw a mean punch :D
russle it doesnt work mate...:)
Glad Niz has sense of humor and forgiveing personality, therefore I am still alive.
Glad niz just laugh it off... otherwise it could been ugly and awked moment...:):D
cheers
Joe
Originally posted by GTS-t VSPEC
Psiker,
Has he got any prices yet? I have a mate who could do it.
Ken, I'll put in a big effort, 3 bounces:p
See'ya:burnout:
my ears prick up :D
he hasnt got a quote as yet. hes taking it to sik em wrex in mandurah to try to find the probelm first i think. would ur mate sell hime a box.(no hooker jokes pls :D ) and is the conversion hard to do ur self?
Psiker
Originally posted by Pva_Glue
russle it doesnt work mate...:D
Glad Niz had sense of humor and forgiveing personality, therefore I am still alive.
cheers
Joe
yes thats why i handled it like i did - but its all good just dont try it again. :uh-huh:
hey paul wont we test before and after - that way u know it'll be all in the name of science haha. :D
Hmmm , if I didn't know better ( pauls gay ) , I would think that you actually almost like him.
Bwahahaha
Cheers
Ken
That's why I said to bring him cos I know you would be safe. Hehehe
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
