  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
Niz , if you like sweet white,
Brown Bros Crouchen Reisling is great.
Wife thinks it's good as she is a sweet white lover
cheers
Ken
yeah had that ken nice drop. Orange Muscat Floras yummy as well cant remember who makes it - i remember the label tho.
Originally posted by Nizmo
yeah got shadows balls cut off poor boy we werent content with doing that - we had to shave the cat as well - he looked shocking, he got his revenge tho he pissed in my car when we moved haha We had to get him shaved cos he had really long hair and he would stay out for 2 weeks at a time in bonking and fighting sprees and come back with his hair all matted and past brushable.
I've shaved few pussies when I worked at VET :P
Lion clip is my favorite...:P or was that landing strip :P
dont remember but it was fun! :D
Originally posted by 33Spec2
hello niz hello paul
thanx 4 your help paul i owe you a drink!:P
had a look at it when i got home - by the way wat is the third wire coming out the cig lighter? the red and black one?
anyway will finish it on friday arvo coz i wanna hav it done 4 friday nite
Obviously you did not read my post b4! shows how much attention u pay!:P
also i have these wires that come up under the drivers seat does anyone know wat these are 4???
Sorry Ken.. i didn't see the question.
No the stick goes into all forward gears perfectly.. all equi-distant. feels like a brand new box.can't tell anything is wrong until trying to select reverse...then it only seems to go about1/2 the usual travel and then as i disengage the clutch, she jumps out.
Originally posted by Kyles
what the hell where you doing with thoes cats joe??
Kyles remind troy boy about a certain debt he owes me b4 he gets you a pressie.
Hmmm , maybe I had better remind him myself:D
Cheers
Ken
awww your cats cute psiker - mines got black and white pretty muc in the same places just its got orange on her as well but she's mostly black and twice your cats size.
She doesnt like anyone but me only comes when i call her - its funny my mum stands a the front door calling her and she wont come in and goes ot me lauren call your bloody cat will u as soon as i call her she's in like a shot. But her and i have a bit of a bond - she picked me i didnt pick her haha
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
