  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Micko,
Did you see the state of Macka's place, think carefully before offering, Naomi might get groped:D
See'ya:burnout:
I run a tight ship mate - they won't get away with messing things up:uh-huh:
If they are game they can try to grope her - reckon the cats will tear them to pieces:bahaha:
