  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Strich9ine
YAY!!!!!!!!!!!!!!!!!!!!!
Booked my clutch in for Thursday morning at Auto Clutch!
DCB 9puck clutch with 2500lbs pressure plate, re-machined flywheel, and thrust bearing..
so all should be right for friday's cruise.... just hope i can "bed it in" before then!
How much was it?
Originally posted by skyzerr33
that setup will be about $850 for kym dan
we should call ross and tell him what a twit kym is so he charges more hehe
AHAHAHAAHAH!!! :-)
the one that PSI did for me is 2600lbs... i have gotten really used to it now :-) i think mine came up to about 850 aswell but brett used a REALLY good quality one and is really not that hard to push in! Troy next time you hoon past gimme a call and i will let ya feel my clutch! not crutch ahahha!tell me what you think of it..
i hated it 1st of all but really am getting used to it... it's a lot different from a hyundai clutch Kim :-)
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
