  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha we all in for 1000 hey? hahahahahaa un****ing believable who would have thought a lil page would be worth so much? hehehehehe :mad:
adrian :mad:
i'm gonna win, i'm gonna win (turns around winds up his nos bottle, checks nitrous pressure, over runs the start line has to reverse back like a loser) heheheh :(
Originally posted by GTS-t VSPEC
Niz,
your probably right, but this server is better than the old one:D
Dan,
If it's not raining I might, who from the RB's are going?
See'ya:burnout:
the G4orse supra will be there, i will go, ummm a few others am hoping ND4SPD goes!!! would like to see it... a few good ones but a few bad ones too, the event is mainly to have fun so you can expect a few 20 sec passes if not from me from someone else..also my friend with a semi worked EF xr6 not bad for a NA 6 hoping for low 14 on that one!
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
