Hey everyone.
I 2nd exhasut torque. $280 for a 3" one piece dump & front pipe is gold.
I've been pm'ing eriktofa behind the scenes. He's actaully not a bad person, just English is his second langauge so his posts are a bit mixed up. For the record, a tissue really did scratch his paint :P Seems like someone did a dodgy job painting his boot and the paint flaked off in places after a wash.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
DCIEVE
if they say no or give u weird looks about putting in a replacement pipe instead of a cat, just tell them its for race use off street, get them to make it up for u, and bolt it in urself when u get home :P ... what has your car got at the moment where the cat should be?
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
