  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
paul,
yeah. 6 is actually pretty slck for me lately. though Ive been pretty lazy get in at about 9 sometimes. :lazy:
Shuto
trust you are well. didly.
PVA,
have you got liftage yet for the day aft the morrow? btw, where do I know you from? did you go to uwa?
We have a sexretary temping at our work. I try not to get distracted, but she's about 17 and......well. anyway.
i hate reception - nothing worse than having to be nice to people the whole day and ansewering shitty phone calls while i was at it. Solution: become bosses PA he gets u out of crap work - life is sweet from then on.
Originally posted by zanda
PVA,
umm no I got no ride... I dont think anyone wants me no more :):D
I may have been at UWA.......(work wise) I go to murdoch.
we have one sexretary too well receptionist. she is hotty :D
cam, you are a bits-whore.
"how come I always think Im gonna score and then I never score!?"
shuto.
will spot me easily provided that I have insurance. ****ing stupid broker can kiss my ass if he thinks Im paying $3300 a year. Im not tree-driving monky umfoofu mutha..........*rant*
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
