  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by G0DF4Th3R
ah where u staying in KL man? u gotta love malaysia
all those cars...
if i was there could show u around
some estate called selagor i think? can't remember the full name.. not staying there for long.. she lives with her folks.. and i think her mum hates me.. hehehe...
Originally posted by Pva_Glue
What about SARS?!? cambell?
sars is for whimps... :)
seriously - more people die in oz of the normal flu each year.. i'll be taking precautions but i think this thing is pretty hyped up.. i mean 3 billion ppl in china and a couple of thousand only are sick? doesn't sound like an epidemic to me..
tho then again i couldn't really say that to any of the victims..
haha kyles sounds like we've got similar wardrobes :) I was thinking um clubbing gear that aint to racey to go cruising in - then figured out i had no such thing haha.
eeew black sambuca i never want to see that stuff again.
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
