  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Dan,
Was it better after the plenum?
See'ya:burnout:
Umm i dunno what it was before but it does look pretty sweeet!!! less piping across the top of the engine bay, kinda neaten things up a lot and polished up nicely, what myself and steve (one of the mechanics there) wanted to know is that there is no weld marks from the plenum to the engine pipe bits... whatever there called?? so did Adam Q send them to subzero to weld the plenum onto from the inside or sumfin??? i would like to know as by the looks of it they have done a really goood job!
AHAHAH! psiker i herreby give you the right to steal the food of them and have it yourself... oh and if you see them smoking feel free to throw a bucket of water at them... just try and run away quickly thats all :-)
lol i gather ur reading back :) a hard task that could be
PPsiker
Originally posted by Psiker
hi mr g and  osc@r
mr g - two ups.... like the coin game? i hope u make some cash :D
Psiker
Haha!!! I actually had to read that about 3 times before I got the joke :D
I was thinking what the hell is he on about??? How are my two UPS's like a coin game and how will they make me any money??? . . . . . . Ohhhhhhhh Two Up the game .... make money ..... ohhhhhh Hahaaa :)
Man I am slow this morning.... Must be the weather... :)
:) ahh man good work im a bit like that this morning too hey :D
Psiker
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
