  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Dan,
Was it better after the plenum?
See'ya:burnout:
Umm i dunno what it was before but it does look pretty sweeet!!! less piping across the top of the engine bay, kinda neaten things up a lot and polished up nicely, what myself and steve (one of the mechanics there) wanted to know is that there is no weld marks from the plenum to the engine pipe bits... whatever there called?? so did Adam Q send them to subzero to weld the plenum onto from the inside or sumfin??? i would like to know as by the looks of it they have done a really goood job!
AHAHAH! psiker i herreby give you the right to steal the food of them and have it yourself... oh and if you see them smoking feel free to throw a bucket of water at them... just try and run away quickly thats all :-)
lol i gather ur reading back :) a hard task that could be
PPsiker
Originally posted by Psiker
hi mr g and  osc@r
mr g - two ups.... like the coin game? i hope u make some cash :D
Psiker
Haha!!! I actually had to read that about 3 times before I got the joke :D
I was thinking what the hell is he on about??? How are my two UPS's like a coin game and how will they make me any money??? . . . . . . Ohhhhhhhh Two Up the game .... make money ..... ohhhhhh Hahaaa :)
Man I am slow this morning.... Must be the weather... :)
:) ahh man good work im a bit like that this morning too hey :D
Psiker
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
