  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Dan,
Was it better after the plenum?
See'ya:burnout:
Umm i dunno what it was before but it does look pretty sweeet!!! less piping across the top of the engine bay, kinda neaten things up a lot and polished up nicely, what myself and steve (one of the mechanics there) wanted to know is that there is no weld marks from the plenum to the engine pipe bits... whatever there called?? so did Adam Q send them to subzero to weld the plenum onto from the inside or sumfin??? i would like to know as by the looks of it they have done a really goood job!
AHAHAH! psiker i herreby give you the right to steal the food of them and have it yourself... oh and if you see them smoking feel free to throw a bucket of water at them... just try and run away quickly thats all :-)
lol i gather ur reading back :) a hard task that could be
PPsiker
Originally posted by Psiker
hi mr g and  osc@r
mr g - two ups.... like the coin game? i hope u make some cash :D
Psiker
Haha!!! I actually had to read that about 3 times before I got the joke :D
I was thinking what the hell is he on about??? How are my two UPS's like a coin game and how will they make me any money??? . . . . . . Ohhhhhhhh Two Up the game .... make money ..... ohhhhhh Hahaaa :)
Man I am slow this morning.... Must be the weather... :)
:) ahh man good work im a bit like that this morning too hey :D
Psiker
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
