  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Its all about using it in context..... I was replying to Boosties post about backing up and I included the diesel generator too.... but going back and re-reading that I suppose to the un-trained eye is could well be taken that way.... :)
Originally posted by Psiker
yay so that means the rain is only half an hour from me. i swear u guys jinxed me
Psiker
Rain can travel faster than the speed of a skyloine... yes hard to imagine but it can... should be comin your way anytime now dude... if ya car needs a wash i advice you put it out in the open! oh and same with your clothes!... this storm could wash the poo stains off the pants of a hyena on laxatives!
lol thanx for the advice man. but by the time the rain gets down here its all filthy after traveling thru the NOR scum that floats in the air and then thru the industrial strip. lol jj
Psiker
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
