Originally posted by GTS-t VSPEC
Psiker,
I noticed that your spelling has improved a bit, have your pudgy fingers lost weight?
See'ya:burnout:
heh either that or im typing a bit slower. too many comments bout my speeeling :D
plus if i have time i look over what i type b4 i submit it :)
Psiker
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
You all shoulda seen the lightning strike on our building (wank best tower). Hit more than 5 times...
power is keep shutting down and up goes back up... for split secound back out :) hahahhaha....
Weather doesnt look good! :D
but still have Great day! :)
ps. Does your mood affected by weather? cuz I do...:D
yeah our power went off n on - we had a great view - we have 360 degree veiws here as far as the eye can see - covering all the north as well so we sat there and watched this wall of water come towards us for 15 minutes haha it was swift and brutal - its ok now tho
My mood gets affected by the change of season - for some reason if i can smell winter turning into summer or vica versa it really gives me a lift - its weird i go all gooey inside haha *yes im a freak*
oh to those following the mysterious adventures of my ebc
the space alien tibetan monk from the moon who were on a time travel jorney into there future past seem to have finally come through with the goods.
i have to pick a parcel at 15:00 which is from japan yay
What is wrong with the world today that you are not showered with the affection of a smitten male? If that is an Ok question to ask. If not I apologies, sorry.
^ email form one of the guys at work who just found out i was single today haha - thats so sweet he's not my type tho hah
so tell him in a past life you were cleopatra and that your car was julius ceaser and ur currently reliving the affair they had or rather u had :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
