Make it ureself even. the only logical reason is for the Salon in which case it need to look nice and all.
Oh and when u first install it make sure u carry a fire extingusiher on the maiden voyage. u never know
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i jsut used to order my lunch and hughsies lunch to come together eat it in the office n surf the net - the days before whoring :) i used to walk the hill a bit too but going past broken hill is really dodgy.
Originally posted by Nizmo
$293 on beer - i think your going to need some help drinking that much beer *hint hint* haha :)
I need no help
FOOLISH MORTALS BOW DOWN BEFORE THE ALMIGHTY BPU.:bahaha:
Hey if ure not driving ill prolly be hanging out of gradenkos car like a goon. illl toss a berr ure way tomorrow. if it doesnt rain.
GTS-t VSPEC, vacum through the oil breather hose? I sure hope you've blocked off/pulled out your pcv valve, cause otherwise you're just sucking oil vapour and unfiltered air back into the plenum chamber. If you've yanked the pcv, then there shouldn't be much vacum to worry about.
I'd still be getting heavy duty hose instead of the clear stuff. Looks a whole lot more "stock" whith thick black hose and no chance of hot oil causing problems.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
