Make it ureself even. the only logical reason is for the Salon in which case it need to look nice and all.
Oh and when u first install it make sure u carry a fire extingusiher on the maiden voyage. u never know
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i jsut used to order my lunch and hughsies lunch to come together eat it in the office n surf the net - the days before whoring :) i used to walk the hill a bit too but going past broken hill is really dodgy.
Originally posted by Nizmo
$293 on beer - i think your going to need some help drinking that much beer *hint hint* haha :)
I need no help
FOOLISH MORTALS BOW DOWN BEFORE THE ALMIGHTY BPU.:bahaha:
Hey if ure not driving ill prolly be hanging out of gradenkos car like a goon. illl toss a berr ure way tomorrow. if it doesnt rain.
GTS-t VSPEC, vacum through the oil breather hose? I sure hope you've blocked off/pulled out your pcv valve, cause otherwise you're just sucking oil vapour and unfiltered air back into the plenum chamber. If you've yanked the pcv, then there shouldn't be much vacum to worry about.
I'd still be getting heavy duty hose instead of the clear stuff. Looks a whole lot more "stock" whith thick black hose and no chance of hot oil causing problems.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
