  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I was there for nearly an hour! Dad put a high flow turbo on it and completley rebuilt the motor in my GTS-X before deciding to keep it for himself and buy me a Corolla. Now I am aloud to borrow it tonight! I am still looking for a new R31 though!
Originally posted by GTS-t VSPEC
Brett,
Are you bringing anyone tonight?
See'ya:burnout:
Hmmm I have a couple of friends comming down in there Honda Prelude..... and I may be bringing 2 friends in my car..... My brother was also meant to come but he now has hockey training.... So yeah I will be bringing a couple of people... I may also still have free seats though :stupid:
