  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
When I fall in love
It will be forever
Or I never fall in love
In a restless world like this is
Love is ended before it begun
And too many moonlight kisses
Seem to cool in the warmth of the sun
When I give my heart
It will be completely
Or I never give my heart
And the moment I can feel that you feel that way too
Is when I fall in love with you
http://comic.yam.com/miluku/tanginlove.htm
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
