  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Zanda - were you the guy that got stuck at the back of the pack with me on Reid Highway?
Was this the cruise that Dan put together ie whitfords , freo , armadale , Canning mills rd , city west ?
Cheers
ken
Micko
yup. stuck good.
I *looks around* hit the speed cut playing catch-ups and then you ROARED past me. felt like a little slowey!
Neo
cam's car aint that far off stock. bit of 'leccy bits here and there and a bleeder....
car is going good. aving it on the road now is choice. getting it lowered again and setting it up the was I want is gonna be even better.
hey aidwin - you think cam's car is bassy, wait till I get the stezza transferred from my old car. 15 inches of loveliness awaits!
Originally posted by SHUTO-BOY
read back paul- Niz has good ideas (burnbury cruise-stay over at her house)
Yea and she's got some double beds. Could be a major problem with who sleeps with who.:D
Cheers
Ken
Originally posted by GTS-t VSPEC
Hehe, I'm reading back already, looks like you boys have been having fun.
Ken, Niz rang me:p I've got a question for you before you go.
See'ya:burnout:
Yes , I would go for it.
Now what's the question ??
Cheers
Ken
Ken, Not a problem for me, I'll sleep with you:p
On the way home after dropping Aidwin home I was driving enthusiastically at the double ton, hard to swerve left and right to avoid traffic, then the car died, I will still doing a ton and a half! Luckily it was in a straight line. Was it just fuel starvation from the sideways action?
See'ya:burnout:
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
