Originally posted by GTS-t VSPEC
Ken,
All the lights stayed on, only 1/8 of a tank:D
See'ya:burnout:
1/8 of a tank was more than likely the prob
I assume that when the car hiccupped you put the clutch in hence the dash lights came on ?
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bah!
Im tired. I go sleepy now. big day of meetings from 8 till 6 tommoz. need to be sharp-ish?!
thanks for cruising today team. had hot time.
(want hot action? call 0055-sex-sau)
and thanks to ken for showing me how to launch at 5,000 up a hill facing slightly sideways on friday night *mental note: dont look at Ken's car then try and race him*. I think you scared the shit out of 3/4 of the chooks at the egg-farms.
nite bitchis
Micko,
Yeah, I think the turbo will need replacing soon, then all you bitches better watch out. I just hope I don't need to brake:D
See'ya:burnout:
Yea , I will take a piece of that action. What are we talking 1/4 mile , laps of wanners , top end speed , MC day ??
Cheers
teh gtr cahnt lose
Ken
Originally posted by zanda
bah!
nite bitchis
Egg farms???
What egg farms or is this some young person thing ?
Cheers
Ken
So would a surge tank fix that problem. Would be scary if it died at 150 going around a corner:D
See'ya:burnout:
Or don't run the car under 1/3 of a tank.
Cheers
Ken
Originally posted by Neo
Night Zanda
Speaking of action guys when are we going to all go to wanneroo or somewhere? I would like to see that.
Unless your car is well set up and you have a lot of money to waste, Wanners is boring.
The average road car only lasts about 3 laps at full noise then the brakes and tyres are off.
Cheers
Ken
Collie and Wellington dam hillclimb are on the 26/27th April
Ken,
Before you do anymore:p After then I would struggle, unless you ran 2WD:p
See'ya:burnout:
Why would I run 2wd . Thats why I bought the R.
btw , I can cos I got a switch in the console. Good for ...err....warming the tyres.
Cheers
Ken
Micko,
I still will have the goods if he has no 4WD:p
Ken, I have my sleeping bag ready:D
See'ya:burnout:
Not a nice way to talk about your g/friend.
Ohh thats right , the hand doesn't answer back. Hehehe
Cheers
Ken
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
