  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah whats wrong with u i got my first diamond ring after four months on my 18th :) my second on my 19th B'day that his sister got an engagement ring just like it - she didnt know tho - i didnt wear mine around her cos it wouldve pissed her off.
