too much writing or not enough brain power macka :P
Worked in car dealerships doing mostly clerical stuff bayley but i have finally got out of it and would prefer to stay out.
Im admin assistant for the government now i do a lot of functions event set-ups and ultimately i would like to get into event management/ PR :D
I thought u worked with your dad - is that who the 6 month contract with or with someone else?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I work at Curtin and they are always jobs going here in admin sought of stuff. It comes out every Friday so I can have a look later and will give you some info on what is available and who to contact. Only if Curtin is not to far away for you though.
That sounds like a dream job alright. Keep working towards it and you will get there!!!
I wanna work breeding horses. Sorry, I know most of you hate horses, but thats my ultimate. Takes big bucks to get there though!
Well its not too far then is it. I will have a look and see whats on later and let you know. Or you can look at www.curtin.edu.au I think thats the website. I will double check that too. Its our home page so I never need to know what it is.
Where has everyone gone? No-one has said good bye!
Yeah, we have tech park too. Even if you get a short term contract, you can get jobs heaps easier in here and you can apply for jobs that people outside the uni can't. Once you have your foot in the door it is heaps easier!
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
