be the same here except we merged with another department recently and everyones jobs are on the line because of it. I just want a bit of security now - it was fun floating around before but ive got a mouth to feed (as in car)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
i wanna "do something naughty" to my cat too,wanna join the flamethrowing band wagon [/b]
Ummm maaaa, never! Already done it.
Sounds heaps better, more deep and stuff. Mine was blocked to so made more power, minutly but still!
um noone ansewered my dumb question - i dont know how it flames nor i dont know why it flames - i do know its something to do with CAT - i just want mine to flame - there are to VX clubbies of my parents that need a roasting plus plenty of hyundai excels that sit up my butt that i would also like to cook :P
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
