  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i work for the govt - doesn that half show haha
Admin assistant but i mainly assist in the set up of functions, meet n greet ambassodors, set up meetings for our overseas office staff while there here along with travel arrangements n stuff - i really dont have enough work on to keep me going but i think some ppl are too lazy to take it on too so they have an extra body they dont really need.
what do you guys think of my idea?
I was asking my marketing department to fork out $2k for a bulk purchase of rubber chickens for a sales incentive program and so far they haven't responded back. Normally they get straight back to me so I am wondering if they might have a problem with it.
A few months ago I had the same request only for $1.5k worth of rubber chickens and they said I needed to come up with some substancial changes to such an idea in order to get funding approval.
Well I changed the amount to $2k. I mean thats a pretty substancial change.
So what do you all think?
