  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
the new layouts dont have the quick reply box :P
and the "User CP" page isnt there :S
ah crap! i see what you mean, once you change to the essentialclass7 (or whatever it's called) you can't get to the CP to change it back and there are quite a few icons/graphics missing.
