  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
hi guys...
man i hate insurance companies....
Hmmm did you just pay your annual insurance fee by any chance?
One thing is though is EVERYTHING on your car legal?? makes you wanna reconsider repaying your bill don't it... you know they will try ang get out of paying for it if in a crash as quick as they can!
yes insurance companies do suck!
dan - nah.. they've more than screwed me... last month it was insured at a confirmed value of 32k (this value is with stereo which they confirmed with me last month) for a bit over $1300.. It's comming up for renewal and they've come back with an insured value of 22k and a premium of $960...
somehow i get the feeling i should get the ky out and get ready to touch my toes..
