  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
didnt mean to be rude - i just didnt see him I dont take much notice of BMW's either haha - was it today?
Ok Ken - u just give me so many "concerned parent looks" i thought that - that would be one of those times hehe i had fun tho felt so sorry for paul :)
Hmmm , concerned parent look.
And I thought I was just perving. Heeeheee. j/k
Yes , I heard that you and mate were a bit giggly.
I would have spanked you ( not ! )
But pwpt60secf can be such a prude sometimes:D
cheers
Ken
haha civics arent that hard to chop - done it before on Stirling Hwy - we hit 140 and i decided I proven my point at that stage cos its a dangerous road to race on - too many other cars about.
Originally posted by SHUTO-BOY
im pretty sure, but i dont think the venue is decided
Ohhh that !
Yea , might try and come for a little while but drink driving is not my scene in a LOUD line.
btw , whats this long distance chat up with Vicki ?
Cheers
Ken
Originally posted by Sneeza
whats on thursday aidwin?
Ken - manual, turbo, r33
Hmm , bugger , got a 94 auto with sunroof which will let go for $19K.
If you want someone to look at it , give me a yell.
Cheers
Ken
Yeah Paul is a bit of a prude haha compared to my ex anyway and he was 3 years older than paul haha people are such a funny species.
I hadnt seen my mate in ages - so we were catching up doing the giggly drunk chicky thing - I spend most of my life around guys so its nice to do the girly thing sometimes :)
Liz i was hoping to bludge a lift too so i can drink but thats cool I'll behave (hmmm thats what i said on sunday) where abouts are u?
Oh Liz u have to keep 10th May free - my birthday party :)
